Follow Us
on our social media
Build4Power Extreme Showcase
The project was started to create the ultimate computer, the utmost in watercooling and performance. Everything had to be custom and everything had to be watercooled. This is where the whole thing started, and what we ended up with was something to behold.
PARTS LIST:
4x GIGABYTE GTX TitanX 4-Way SLI
Gigabyte X99 Gaming 1 Black edition
Intel 5960X Extreme Core
Corsair Vengeance LPX 64gb DDR4 @3600Mhz Memory
Samsung 950 Pro 512gb SSD M.2 2x WD Black 6tb HDD Raid 0 2x
CoolerMaster Master Watt 1200 power supply 32x
CoolerMaster MakerFan 140mm fans
All is going to be liquid cooled by Bitspower components for all of the hardware.
1x Bitspower THOR GAIX99 Nickel Plated Full-Covered-Block (Clear) Model Name:BP-WBTHORGAIX99FCBNPAC-CL
4x Bitspower VG-NGTXTITANX ACRYLIC Nickel Plated Model Name:BP-WBVGNGTXTITANXNPAC
2x DIMM4 Block V2 Model Name:BP-WBDM4ACV2-CL or 2x BP-RAMS44V2-CLBK
4x 560mm radiator 32 x CM Silencio Fan Red 140mm Fan
4x Water Tank Z-Multi 400 (POM Version) Model Name:BP-WTZM400P-BK
4x D5/MCP655 MOD KIT (Abrasive Silver) Model Name:BP-D5MA-ASL
4x Bitspower D5 MOD TOP (Clear “S” Model) Model Name:BP-D5TOPACS-BK
4x Bitspower Flow Sensor Silver Shining Model Name:BP-FS-CLBKSL
2x BP-HDS350AC-CL
8x BP-MVV-SLBK Silver Shining
12x BP-YB Silver Shining
16x BP-30R Silver Shining
32x BP-90R3D Silver Shining
4x BP-ETAIR Silver Shining
4x BP-WTP-CT Silver Shining
120x BP-WTP-C89 Silver Shining
4x D5 pump 12V DC PWM Pump Motor Radiators from phobya 4x 560mm
*Case Mod World Series 2017 Entry
Modder
build4power
Country
Netherlands
Worklog
Forum
Category
CMWS, Mod Gallery, Scratch, Scratch Build
  • wK
    crazy
